Symptoms of a clutch that needs replacement?
I noticed about a month ago, if I redlined a gear and switched to the next, the car would just rev for a bout a second before the gear engaged and the car started to acclerate again. Now about a month later it has gotten noticeably worse. If I'm just cruising on the freeway at around 60mph and decide to pass someone up in 6th gear, i'll press on the gas and it will acclerate up to around 62mph and then the rpm's will just rise and I have to let go of the gas and press it a little bit lighter so that it accelerates instead of revving. I'm guessing this has something to do with having to replace the clutch. If so, what components would need to be replaced, and how much am I looking to spend? The car has roughly 30k miles on it.
mine isnt that bad it stills grabs second hard but sometimes going into 2nd around 8k if i pop the clutch it will hesitate for a split second almost like the clutch cant handle it but then it doesnt happen at 8900 what do u guys think
Try bleeding the fluid first and see if that helps. If not you could try adjusting the pedal. If those don't work, you need a new clutch. Honestly I am guessing you do since it is already slipping in 6th gear.
Peter
Peter
sounds exactly like what i'm having but mine is worse. My car slips bad in every gear now. I bought the clutch kit from hardtopguy.com (thanks Jeff ) and i'm getting it put in tomorrow. The tranny shop is charging me 400 + tax which from what i can tell isn't all that bad.
Now the clutch kit from Hardtopguy comes with a new flywheel (comptech) which elevates the price a bit. You might only need a new disc or pressure plate or both. Just for numbers sake, assume you need a new clutch (disc & PP) and with labor, you're looking at roughly $1000+/-. if you shop smartly you should be able to get below that if you want.
Originally Posted by s2krazy01,Nov 9 2005, 10:45 AM
do you launch your car often? I'm at 36k miles on MY00' and my clutch had no problems, but i don't launch.
Sounds like your disc is glazed...what it is ...is when u step on the gas its trying to grab the pressure plate but the clutch disc is melted really smooth like glass probably....it happed a couple a time from me racing my integra alot....im willing to put my money on thats what it is...if ur going to replace your disc like you should u mind as well go head and replace the pressure plate so you wont have to do it later on and u can launch harder with a new pressure plate...hope i helped...
Jon
Jon
johnquester2000
12-04-2008 09:45 PM
