symptoms of a clutch going bad?
just started to happen today, drives fine without any slipping at all. sometimes hard to get out of 1st gear and reverse only. even with the clutch pedal completely pressed in, the car still feels like the clutch is slightly engaged with a tad of jerking. only very low speed 2<mph in 1st and reverse only. checked the master cylinder which had a slight leak and has been changed. the slave is fine with no leaks at all also. bleed correctly til not no air bubbles are left at all. symptoms of a failing clutch?
When I changed my CMC the clutch pedal was still engaging very close if not against the floor boards. There is a little adjustment screw on the back of the clutch pedal I would try moving the clutch pedal up towards yourself before changing the clutch. It's cheaper(free) and might fix it.
How many miles are on the current clutch
blacks2k
20
03-06-2007 08:44 PM
