Sway bar help
I installed a Cusco front sway bar a while back and I'm getting all sorts of rattling/squeaking noises from it. I installed it as per the Honda service manual and I double checked to make sure I did everything correctly. The only thing that seems wrong is that the end links are rubbing against the shock body. Is this the noise I'm hearing and is it normal? Or did I install it wrong?
