Swapped my Plugs, what y'all think.
I only DONT use anti-seize with NEW ngk plugs (which is all I use). If I'm pulling them for inspection or a comp test or something I apply just a little bit and put them back in.
BTW your old plugs look great. Looks like they have a lot of life left tbh.
I torqued to 20ft# as per DIY. And car idles smooth with new plugs. Placebo effect of new plugs, because old plugs was also smooth lol. I love this car.
Next, I'll be changing diff and tranny fluids... Hope these fluid pumps I bought work well. Ended up with Mobil 1 75w-90 gear oil (1qt) and Honda MTF (2qt). Just waiting on washers to do the job.
Received 1,753 Likes
a tiny bit of anti-seize is fine, particularly if you are going to leave the plugs in for the recommended 100k miles.
NGK doesn't recommend it on their new plugs as they have a coating on them, but if you ever remove and reinstall the plugs then you could use anti-seize on them. I like to use a small bit to keep the threads from going dry and galling /rusting.
BTW, I solved the problem with the socket detaching by getting a Craftsman "locking" extension; it has a black lever that locks the ball bearing so it cannot detach from the socket until you unlock it.
http://www.ngksparkplugs.com/pdf/tb-...1antisieze.pdf
