swapped engine..and CEL light...help~
ssup guyz,i own a 2003 s2000.i recently swapped the engine.new engine has only20k. now i have CEL light,and everything on the car is 100% stock. i scan the ecu and it tells me that there is nothing wrong with the car(no code at all). what could it be?
should i reset the ecu? help~~
okay i got the code now....itz p0135-02 sensor heater circuit malfunction (bank 1 sensor 1). im kinda confused becuz the sensors(front and rear) on the car is brand new. and tried to clear the code but it wont dissapear.
and also when i start the engine itz not there, but when i rev the engine then it comes out. could it be the wire of sensor? the ones from the engine or what ever? machanic told me that the computer is not sending anything to sensor. do i have to reprogram the ECU?? help!!!~~~~
