Swaping tops ap1-ap2
Old 10-25-2006, 02:54 PM
s2krey's Avatar
well the guy is giving me $$$ for the swap so might as well make money, plus the car is going to a dealership and wont know the diff. In fact they didnt even know what a S2000 was and by who.
So is this confired though? no problems with top up and down?
Old 10-25-2006, 03:00 PM
silentdancer's Avatar
no problems if everything is swapped
Old 10-25-2006, 03:34 PM
alejo's Avatar
good luck with the swap - major pita but it can be done within 8 hours with short breaks.
Old 10-25-2006, 03:38 PM
WolfInSheepsClothing's Avatar
It is a pain in the a$$ to reach some of the bolts/nuts (especially if you are 6'3 ), but it's definately do-able even for the average person
Old 10-25-2006, 06:27 PM
AusS2000's Avatar
I think you'll regret it when you get half way through the procedure. It ain't easy.
Old 10-25-2006, 06:57 PM
duff0000's Avatar
[QUOTE=centralcoastbuc,Oct 25 2006, 06:06 PM] If his was originally plastic, you will have to do a mod.
Old 10-25-2006, 07:13 PM
s2krey's Avatar
thanks for all the info...
more are welcome...now to think if i wanna do this...
Old 10-26-2006, 04:08 AM
CoralDoc's Avatar
To summarize:
If you swap the entire assembly (frame, top and window) the procedure is straighforward, though time-consuming.
If you want to install a newer top with glass window on the frame of a car that originally came with a plastic window, you will need to do some "custom" modifications. Plus, the procedure itself is somewhat more tedious.
The procedure is listed on this site. Check the Library and then in the FAQ for Under the Hood as a start.
Old 10-26-2006, 07:38 AM
s2krey's Avatar
thanks to all! your help is greatly appriciated!
-Rey
Old 10-26-2006, 08:03 AM
centralcoastbuc's Avatar
Originally Posted by duff0000,Oct 25 2006, 06:57 PM
Not true, You can swap an 02-06 top and frame to 00-01 by just bolting it on.
Now if you want to swap and 02-06 top onto an 00-01 frame, you have to make modifications.
Correct. I didn't catch that he was swapping the whole assembly.
ktwenty
02-10-2015 05:37 AM
dirtys2000
02-04-2010 07:34 PM
bam9382
11-22-2008 08:39 AM
YelloS2K01
07-14-2008 08:53 PM
Quick Reply: Swaping tops ap1-ap2
