SWAP engine F20C AP1 to AP2
Maked someone the SWAP AP1 F20C engine in AP2 2007 with DBW throtlle.
Is that SWAP easy and possible? Any problems?
I have F20C turbo engine, Ap1 harness, AEM ECU. I cant sell this motor.
Thanks guys.
PS: sorry for my sux ensglisch, i hope, that you are understand me, its very important for me
Thanks guys.
Yes, it will bolt right in. That assumes your AP1 motor is complete. Things like the intake manifold, valve cover, engine harness just to name a few can not be part of the unswapped parts. Your EMS makes this work.
Good point, I have not looked in that area, but it makes sense that you would need to. I think one other has talked about doing this (posted) but I do not know if he did the swap or not. Search??
I don't think that would be required. The cluster is it's own computer. To change it, you would need to change the dash wiring harness too. I know that the AP2 and AP2 cluster is differant and the 06+ cluster is differant yet again. But I still think the above holds true regaurless of the year.
I have MY07 car with DBW and AP1 engine MY03 with AEM EMS.
I red many threads here, but I found out, that the SWAP AP1 in AP2 MY07 isnt so easy. ECU is different (VSA, DBW...). How work after VSA and more things, if i change the ECU? Or AP1 ECU have same connectors like Ap2 ECU?
Fuel pump (06+) is too different than 00-05. I dont know, if my Walbro pump will work on my MY07.
Please have somebody experiences?
I cant sell my car :-/
Many thanks and sorry for my english
I showed on AEM EMS and AP1 engine harmess and I found out, that to the ECU join on the engine harness and one conector is for IMO, A/C, Fuel Pumpe, Air control Valve ...
Can I change the ECU from AP2 MY07 for AEM EMS 00-05? Conector cant be same or yes?
Please help me
Please help me
