Suspension Squeak/Creak Over Bumps
Old 10-04-2009, 12:26 AM
toniotran's Avatar
Wink Suspension Squeak/Creak Over Bumps
Hi fellow s2ki members. The problem that I've been experiencing is a creaking/squeaking noise that occurs mainly when I go over speed bumps at low speeds and when I drive over irregular street pavements. The sound is more of a rubber squeaking contact sound rather than a metal on metal grind or clunking sound and is noticeable in both the front and rear. Did a search to narrow down the solution but had no luck, so if anyone has any helpful advice please chime in.
Old 10-05-2009, 12:18 PM
toniotran's Avatar
Thoughts, anybody?
Old 10-05-2009, 12:33 PM
rob-2's Avatar
I sometimes get this but figured it was my soft top. Sounds like crickets.
The bumps have to be just right, rolling and I need to be going fast enough. Hard to pin point the location
Old 10-05-2009, 01:11 PM
Lefty2Guns's Avatar
I have had this issue as well and have not been able to isolate where it is coming from. Hopefully someone has some information on this
Old 10-05-2009, 02:44 PM
toniotran's Avatar
To add just a little more insight on the sound, it sounds like a rubber bushing that needs to be lubed/greased. Also like to know if its something serious enough that could lead to bigger problems if not fixed
Old 10-05-2009, 02:46 PM
booski's Avatar
i believe its normal.
Old 10-05-2009, 08:22 PM
berlina2ks2k's Avatar
i have a sound like this too, but it happens very often when driving slow, im just guessing i cant here it when i drive faster
Old 10-05-2009, 08:28 PM
watchdogd's Avatar
How many miles do you have on the car or more importantly the suspension. My old integra did something simialr but it had a lot of miles.
It could be the bushing or struts. I had my front struts replaced on the S but that was from a clunking sound.
Old 10-05-2009, 11:35 PM
toniotran's Avatar
[QUOTE=watchdogd,Oct 5 2009, 08:28 PM]How many miles do you have on the car or more importantly the suspension.
Old 10-06-2009, 06:06 AM
booski's Avatar
its not suspension, i just changed out my coilovers a few thousand miles ago and it still does it.
Quick Reply: Suspension Squeak/Creak Over Bumps
