suspension mounts/ bushes
Hi all
was reading a thread on the uk part of the site about the suspension mounting bolts and adjustment cam-bushings
If you live in the southwest this is probably irrelevant as it hardly rains
if however you live where it rains or they put salt on the road you had better remove the suspension bolts and adjustment bushings as they will start to corrode in solidly and you wont be able to adjust the castor angle / camber and toe in
once removed a little wax or grease in the bushing / bolts will allow you to run on trouble free for years to come, do all the bolts that go in a bushing .
I used aerosol spray wax that is used for the rustproofing of hollow areas in the bodywork
for further information look to the faq section of the uk site
Paul
Paul
