supercharging car soon need ideas to make max power and tuning
Old 04-09-2012, 05:42 PM
  #21
Sherman818's Avatar
Originally Posted by Sherman818
Originally Posted by drkphnx' timestamp='1334019815' post='21592334
[quote name='Sherman818' timestamp='1334019679' post='21592325']
[quote name='Moddiction' timestamp='1334017085' post='21592188']
[quote name='Sherman818' timestamp='1334013450' post='21591986']
[quote name='Moddiction' timestamp='1333984020' post='21589991']
You definitely need a fuel pump. Not maybe. You can try and run the kit off the fmu it comes with but many people, myself included have run very lean with it and had to upgrade to standalone ecu and injectors.
A wide and gauge I'd say is 100% necessary.
so i should get the fuel pump and what size injectors?
what stand alone would you suggest? should i order the 3 bar map sensor?
Yes you do need. Fuel pump regardless of what you do for tuning.
If you are going to go the standalone ecu route than I would suggest the Injector dynamic 1000cc injectors.
If you are going to spend the few grand for an ecu, injectors, tune etc you might as well upgrade to higher boost which in turn you would need a new clutch, map sensor etc.
[/quote]
i plan on getting the fuel pump. will i be ok to hold off on the stand alone and injectors for a month or so with the low boost for now. i already have a stage 3 clutch with a couple thousand miles on it. thanks for all the help
[/quote]
I would wait till you have everything on hand, no reason to install everything for low boost tune, then a month later up the boost or add more mods and retune, waste of money imo. I know you want to boost asap, but do it right the first time to what you want, don't cut corners, especially when going FI.
[/quote]
[/quote]
Old 04-09-2012, 05:43 PM
  #22
Sherman818's Avatar
Originally Posted by Sherman818' timestamp='1334021789' post='21592432
[quote name='drkphnx' timestamp='1334019815' post='21592334']
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
Old 04-09-2012, 05:47 PM
  #23
Former Sponsor
Moddiction's Avatar
Depends if you need obd2 or not. Aem ems will get rid of that and all cel functions etc. they work great and lots of good tuners for them. Kpro is another option but is more expensive and more things to swap over etc.
Only need the map sensor once you have the ecu, injectors and a smaller pulley.
Old 04-09-2012, 06:20 PM
  #24
Sherman818's Avatar
i have the fuel pump on order along with the wideband and upgraded oil jet bolts. can i have my car tuned with a stock ecu? what about greddy emanage? AEM Series 2 Plug-N-Play EMS for 00-05 Honda S2000 is this what you suggest? i also have the injectors on order
Old 04-09-2012, 06:36 PM
  #25
Former Sponsor
Moddiction's Avatar
You cannot tune the stock ecu. You can get an emanage. Not as good as a full standalone and also cry hard to find a capable tuner for it.
Personally I would go with the AEM EMS. If on a budget can find some good deals on used 1052 models.
Old 04-09-2012, 06:55 PM
  #26
Sherman818's Avatar
can i used an aem wideband on stock ecu
Old 04-09-2012, 07:04 PM
  #27
steven975's Avatar
yes. the AEM wideband is capable of standing alone, or it can be used to feed data to a standalone ECu.
Old 04-10-2012, 04:38 AM
  #28
Sherman818's Avatar
i plan on getting the stand alone and the injectors next month
kyof20c
03-11-2016 09:46 AM
westfield147
04-16-2012 11:23 AM
hondaguys2k
15
03-16-2011 05:36 PM
Gamble
04-08-2010 07:57 PM
s2000Junky
04-03-2009 04:13 PM
Quick Reply: supercharging car soon need ideas to make max power and tuning
