supercharger vaccum psi??
I was just wondering what other votech guys are running as a far as a vaccum pressure at idle?? Just mostly curious.....
Originally posted by NYYellows2k
Wouldnt it be boost?
-YS
Like someone else said, assuming you have no vacuum leaks and whatever engine management you're running is working properly, it should be the same as stock. I don't have an S2K service manual, but most modern Hondas idle right at 19 - 20 inHg with no accessories running. Flip on the A/C, and it will jump to about 17 inHg. You should be able to make an adjustment on the throttle body's idle control screw if necessary, but that's just a band-aid for poor tuning.
12gage
10-30-2002 02:00 PM
