Supercharger BOV idle setting
#21
I had a post about this to a while back. My Godzilla also leaks air at idle actually at cruising its gets annoying. What Aus is saying about it being a bypass valve instad of blow off valve is right.
I might switch BOV I dont like the sound of the Godzilla.
#22
Aus2000: Them model I have is for the Audi 1.8T and has a 25mm inlet and 25mm recirculation outlet. I need an adapter that will mate the 25mm air hose to the rubber Comptech intake hose where the original Bosch valve was.
I guess if I can't find this type of fitting I can just modify the old Bosch valve by hollowing it out and sealing hole where the vacuum hose goes. this will essentually make it a 25mm right angle hose coupler.
Revhi: Couldn't you just adjust the spring tension on the Godzilla so it doesn't leak during idle? Let me know if you want to sell it or perhaps trade
#23
You shouldn't have much trouble finding an adaptor. Try a plumbing or auto shop and take the Bosch unit with you for sizing.
Personally I think you have chosen the best option to replace the Bosch unit. I had heard that our valves were used on Audis and VWs so I guess it makes sense to use what they use. And the Stealth lets you choose between plumbback and PSSSFFT sound at the twist of a dial.
BTW, what did you pay for it in the US? They are about $AUD500 here.
#24
What is better the godzilla or the stelth FX?????? What size do u need for the Comptech unit????? Where is the best place to get it???? I want to put a bov on just for a little sound.
#26
I got mine off of ebay for US$265, which is pretty expensive for a BOV.
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...sspagename=WDVW
It is the one for the Audi 1.8T, comes in 4 colors.
Or alternately you can get the GFB Hybrid for US$175.
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...&category=33742
The differences are minor;
-- the Stealth FX has a rotating vacuum nozzle while the Hybrid is on top of the unit
-- the Stealth FX is adjustable from 0%(fully recirculating)-100% vent to atmosphere while with the Hybrid you have 3 settings fully recirculate, fully vent, or a 50%/50% combination.
#29
Im really not to crazy about my godzilla sound i want something a little more high pitched. I know a guy who just got a HKS i think i got to hear it.
I paid 350 for the Godzilla from tech2
