Sudden problem: rough idle, loss of power, loud
As a rather non-mechanically inclined person, I need advice. The "check engine" light came on yesterday while driving. I know the manual (yes, I actually pulled it out!) says it's probably am emissions issue. I tried the gas cap fix, but that didn't work. The car is now loud (as if there's a hole in the manifold or exhaust), idles rough and erratically (as a prior Porsche did, but that was a busted motor mount), and won't accelerate like it used to. Is it just a loose emissions/vacuum/whatever hose? Can I fix it myself, or do I keep the appointment at the dealer? Could the "check engine" light mean something more than just emissions? Is it a back-pressure problem with the muffler/exhaust that's causing the situation? A hole or leak in the exhaust manifold? Any suggestions would be most appreciated. I'm sure (or, at least I hope!) it's nothing expensive or terminal. Is it a common occurrence? Thanks.
Originally Posted by blkatz1,Aug 22 2006, 01:39 PM
As a rather non-mechanically inclined person...Can I fix it myself, or do I keep the appointment at the dealer?
- Dave
Kept the appointment. Dealer said it was a bad ignition coil. Makes sense to me. Hopefully, I didn't fry the catalytic converter (what I smelled was probably the converter heating up as it worked overtime to handle the unburned fuel from the misfiring/non-firing cylinder). Questions: Does each cylinder have a coil, or is their just one? And, will the converter be O.K.? Only problem, no part available. They hope to have one today. Thanks for the help and encouragement, BTW.
One coil per cylinder. Hard to say on the cat. When you get it fixed, if you get a convertor efficiency CEL after awhile then you probably killed the cat.
The car will tell you thanks to OBD2.
silversonic
09-27-2002 10:40 AM
bluegene
09-08-2002 02:24 PM
