sucked up water w/aem v2 last night
Old 10-05-2006, 11:03 AM
  #21
RED MX5's Avatar
[QUOTE=rustywave,Oct 5 2006, 08:49 AM]how do the V1 and V2 differ?
Old 10-05-2006, 01:16 PM
  #22
Boofster's Avatar
Grats on starting your engine.
Two notes. AFAIK you can't use bypass on V2. Those with V1, get a V2 Also, some water sprayed into the engine is actually good for it. Water cleans the carbon deposits very well. Almost like that seafoam stuff. Of course too much will choke it. I recommend revving very hard if you ever get into a situation where water gets into the engine.
Old 10-06-2006, 12:10 AM
  #23
vishnus11's Avatar
Interesting perspective and useful info in case I find myself driving through some deep water and have no recourse but to keep going. Could you please explain the reason behind this? I'd always thought that if I ever did find myself in a lot of water, the best thing to do would be to shut the engine down before any water entered the cylinders, and then have it towed or drive it after water has subsided.
Old 10-06-2006, 05:44 AM
  #24
rustywave's Avatar
Originally Posted by RED MX5,Oct 5 2006, 02:03 PM
Notice how the V2 uses two different diameters of piping? The V1 pipe was a constant diameter over its entire length. Both are tuned pipes, but the V2 produces two primay peaks whereas the V1 only produces one. Of course both produce harmonics and sub-harmonics. Think of the two different sized pipes as making up two different acoustical chambers. At the step there is a velocity and pressure change that I *believe* will break up any block of water, so (in theory at least) you should only get some mist into the motor rather than a big gulp of water with no air (which is what causes hydrolock with the V1). Please keep in mind that this is not something that has been proven the way the bypass valve on the V1 has, so I cannot be absolutely certian that hydrolock is impossible with the V2. I think it is at least less likely, and probably impossible, but I have no way to be absolutely certain.
I am certain that V1's can cause hydrolock, and running a V1 without the bypass valve is bad medicine.
ah i see...well whatever the reason, i'm glad my engine didn't get destroyed! i can't imagine a whole wall of water getting sucked through into the motor...just a couple small splashes caused enough trouble as it was.
Old 10-06-2006, 05:46 AM
  #25
rustywave's Avatar
i was wondering the same thing as well...i'd assumed that the reason i didn't cause damage was because i was going so slow, so a strong enough vacuum wasn't created to suck up enough water (along with the 2-size piping the V2 has i guess, as explained by red mx5).
Old 10-06-2006, 05:48 AM
  #26
rustywave's Avatar
oh, and after changing the oil yesterday, i drove home with no problems. waited about 10 or 15 miles before i revved it hard, and it seemed okay. looks like i dodged a bullet.
no more attempting to ford a river oregon trail style.
Old 10-06-2006, 08:12 AM
  #27
Banned
Kyushin's Avatar
Good to hear youre ok bro, i never installed a CAI for i live in fla where it monsoons like everyday and IMO dont feel an theorized 2-3 hp is worth the risk it imposes, but alot of them do sound really good though, and again, good to hear your cars in good shape
mav
06-04-2008 07:14 PM
NIXS2K
06-23-2006 04:06 AM
FJahandari
06-12-2005 10:16 AM
pinoyhero
05-27-2004 08:19 AM
Hyper-X
03-25-2004 08:37 AM
Quick Reply: sucked up water w/aem v2 last night
