Sub frame bolts
Sub frame bolts
i think my subframe is bent only a little but i bought another one to replace it.. will i need to buy new subframe bolts just in case the old ones are bent?
the website says i only need 4 of number 12 bolts.. is that correct?
which are
90164-S2A-000 12 BOLT, FLANGE (12X162)
which are
ok i tried ordering the subframe bolts.. but they tell me that they are on back order with no ETA... that means they do not know when will they come in..is there any other bolt i can buy at a hardware store that fits?
I replaced that cross-member a month ago. It's mounted by 6 big bolts, 4 of those labeled 12 and 2 8s. the 8s are a lot longer. it's a major PITA, took me 2 days.
My car sat on level ground as if there was a fat dude sitting in the driver seat - not level, even though there was noone there. I thought a gas shock lost some pressure and wasn't holding up the right rear quarter. Turns out the whole frame of the car was twisted like a propeller, but only about 3/4" . a frame shop took care of that, shouldn't have replaced that cross-member.
Hey, don't bother replacing those bolts. The ones you've got are already stretched, and won't need to be re-torqued if you reuse them. I did, all's fine.
Mark K.
Mark K.
