The stupid spark plug cover...
Old 01-11-2009, 12:26 PM
  #41
SgtB's Avatar
Put the key in, hold pressure on it counter clock-wise, and then smack the end with a rubber mallet. It's gentle and very controllable.
  #42
ChefJ's Avatar
gratz on bumping the oldest thread ever.
spray the bolts with pb blaster or wd40.
Spark plug covers are useless cosmetic pieces.
Good luck.
Old 01-13-2009, 01:46 PM
  #43
smallville160's Avatar
Dude i totally feel ya i had the same problem with all of mine i think the problem is someone cranked them down tight then the constant heating and cooling siezes them up i tried everything for mine hex keys hex head sockets also tried puttin liquid wrench and WD40 i tried heating up the engine and i tried super cooling it with some liquid nitrogen finally i got made enough i took a drill to it and while drilling each one they all came loose and i got them out found replacements very very cheap at LOWES
Old 01-13-2009, 03:44 PM
  #44
Slows2k's Avatar
Don't use a worn out Allen driver, don't use an SAE one either. Use only a Metric driver that snugly fits the hex. If it's loose, you'll mangle the bolt.
It's pretty basic hand tools use.
Old 01-13-2009, 04:33 PM
  #45
ahrmike's Avatar
Yep. and if you want to keep your cover afterwards, dont forget to make it SNUG.
I thought I'd outsmart the damn thing and finger tighten + a little more.. I developed a serious rattle from the engine, come to find out one bolt loosened itself and ran away, and three of them were pretty much backed all the way off and about to follow the first bolt out. Cover was rattling all over the place.
Old 01-13-2009, 07:14 PM
  #46
RedY2KS2k's Avatar
44 posts about a spark plug cover and 4 socket-head capscrews?
Old 01-13-2009, 07:15 PM
  #47
Slows2k's Avatar
daileyboy81
10-01-2014 07:27 AM
Skatethesea
02-08-2010 02:25 PM
JiNSOKU
03-17-2009 05:09 PM
scottieboy561
10-18-2008 03:31 PM
S2KMan2000
12-21-2006 09:06 AM
Quick Reply: The stupid spark plug cover...
