Stud broken off while installing header..
Old 10-10-2013, 12:24 PM
Car Analogy's Avatar
Received 1,466 Likes on 1,084 Posts
If vise grip ends up just slipping and stud won't come out, apply heat to the stud, then try again.
Use a blow torch and get as much heat on it as you can. Should come out then.
Old 10-12-2013, 04:25 PM
slalom44's Avatar
I have never been a fan of using vice grips for getting out a stubborn bolt. You might try a miniature pipe wrench, assuming there is enough to grab on to.
Old 10-12-2013, 06:41 PM
SpiritofSenna's Avatar
Thank you for your help guys ! I was able to take out the broken piece and reinstall perfectly.
Although, you guys must be hercules or something because I could not finger thread in the bolt at all..It took a lot of force.
Old 10-13-2013, 06:29 AM
When you broke the stud it was probably due to overtorquing (either now or on some previous instance that stretched and weakened it). So that caused the stud to be wedged into the head tighter than normal. This probably buggered up the threads a little, so new stud was more difficult to put in.
20civic07
04-02-2013 07:25 PM
marknconnie
06-27-2010 06:48 PM
hypforlife32
05-11-2010 07:52 PM
kamui157
11-17-2008 05:21 AM
johev
09-13-2001 10:17 AM
Quick Reply: Stud broken off while installing header..
