Strut Tower Brace
Old 02-18-2008, 07:18 PM
S2Race's Avatar
damn honda really did dial in this chassis then... all this time ive been looking for a cheap one that would work well to help times a little bit. guess i should quit wasting time...
Old 02-19-2008, 04:26 AM
DeeDubya's Avatar
Originally Posted by Ludedude,Feb 18 2008, 06:43 PM
When cornering, there's exactly zero pressure on the top of the shock mounts. This car doesn't have struts, there's no load path to the top of the shock like there is in a strut suspended car.
Just tighten the thing up and use it to lean on when changing the oil or working under the hood.
Actually my son gave it to me so I was obliged to install it. Just wanted to do it right.
He had heard of a test that someone did. They tied a taught string or wire from the top of one shock tower to the other. After a run on the track the wire was broken, which would indicate that there is some flexing.
Old 02-19-2008, 07:07 AM
street_ruler's Avatar
if you wanna do it "right" the idea is to have pressure going outward. meaning the bar pushing the towers "out" thats how to preload the towers. but in all truth this car has a great chassis and tons of factory bracing so it shouldnt be needed. but it does look purdy
Old 02-19-2008, 11:04 AM
afwfjustin's Avatar
Mine was free and I use it to lean on when doing engine work. It's absolutely not doing anything but adding a pound or three though.
Old 02-19-2008, 01:30 PM
oakfloor's Avatar
Try a cusco "U" brace, its light and does not get in the way of an oil change, and made a small difference on my car as to turn in response. So much that I wont be taking it off any time soon.
Old 02-19-2008, 01:32 PM
S2Race's Avatar
a cusco U brace? where do you get them?
Old 02-19-2008, 01:37 PM
oakfloor's Avatar
Try a cusco web search. I have mine for so long I dont recall where it came from.
Old 02-19-2008, 02:34 PM
kuruma's Avatar
Is that the Brace that goes on the bottom? If so I have that bottom Chassis stiffener and I noticed a small difference, in that the car tended to handle more flat through the corner.
Old 02-19-2008, 03:39 PM
oakfloor's Avatar
Yes, that one. I noticed the same thing.
Old 02-19-2008, 03:41 PM
S2Race's Avatar
i might not have the Cusco one, but i have a comptech underbrace, or so said the guy i bought it from. im not sure.
Quick Reply: Strut Tower Brace
