Strong Gas Smell in Cabin after running Heater
Old 02-09-2014, 07:39 AM
Billman250's Avatar
Received 1,338 Likes on 810 Posts
Also check for loose spark plugs.
I had a customer complain of the same thing and it was loose plugs.
Old 02-09-2014, 09:48 AM
Chance S2K's Avatar
Originally Posted by JFUSION
Remove the plastic fuel rail cover. Get a bright flashlight and pressurize the fuel system by turning on the ignition, and check around under and around the intake manifold and fuel hose area. You don't have to start the car at this point. Your nose might lead you to the right location, lol. Look for light moisture around all of the fuel related parts, you probably won't see large drops of fuel, it's going to be a very fine amount of fuel spraying or oozing out from one of the parts. The fuel hose that mounts under the fuel pulsation dampener has a joint in it about 6 inches below the intake manifold, that would be a good spot to check, you need to look down between the intake manifold runners with a bright light shining on the metal portion of that hose.
Good luck.
I still can't see the leak, but I was able to smell the fumes and hear some sort of pressure escaping around my fuel rail (so I'm beginning to suspect a bad injector O-Ring). Do you know of any decent guides to removing the fuel rail? I've tried searching but haven't really found anything; at the moment I have it about halfway removed but I'd like to know that I'm doing it right.
Thanks for the tip, but they check out alright
Old 02-09-2014, 11:16 AM
Ruble03's Avatar
I had the same issue with my turbo setup. I got a catch can which reduced blowby. It helped me. Don't know if would help you at all.
Kidblast
09-03-2016 01:17 PM
Jeremy Clarkson
06-01-2013 09:35 PM
machviper9
12-05-2007 09:25 PM
spdemon12384
07-03-2006 09:38 PM
wanabe
05-31-2001 10:49 PM
Quick Reply: Strong Gas Smell in Cabin after running Heater
