Strong Gas Smell in Cabin after running Heater
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-3yr.png)
This is my first time going through a hard winter with my S2K, and in the last couple weeks when I've gone out to start the car and let it warm up, I've noticed that there is a VERY strong gas smell in the cabin when the car is idling with the heater running. The smell will linger for quite some time until I shut off the heater and drive the car around more.
It only happens when I have the heater on, and I haven't really noticed any significant drop in MPG. I can only assume that I have a leak somewhere, but I can't figure out where would be a good place to start searching and I can't think of any fuel line that would have anything to do with the heater.
If anyone has any ideas or tips I'd appreciate it.
Edit: I should also probably mention that I'm not seeing any liquid on the ground; I can't visually see any leaking gas. I can only smell it, however the smell is unmistakable and extremely strong.
Check under the hood? Your pressure regulator may be leaking shooting gas into the blanket on the hood (which explains no puddle on the ground). As for the smell only coming on when the heater is on... not so sure bout that one.
When a car is cold and trying to warm up it runs rich. This can be exaggerated even more during winter months where it's even colder. It's not uncommon to smell unburnt fuel during this time. Could this be your issue and maybe you just think it's heater related?
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
You are smelling it with the heater on because it is sucking air from underhood and introducing it into the cabin, it isn't related to the heater directly, so the source of the leak is in or under the engine bay.
The source is going to be around the fuel rail, check the injectors, and the most likely culprit is the fuel hose that comes up and meets the fuel pulsation dampener on the fuel rail. The metal part of the hose just under the intake manifold is brazed at the joints and we've seen pictures of the hoses leaking there.
Have you had any work done to the intake manifold area of the engine in recent times ?, sometimes the fuel pulsation dampener can leak if it isn't tightened properly and new washers weren't used. Otherwise the fuel hose, fuel pressure regulator, and injectors would be the next place to check.
I'd stop driving the car until you find the issue, we've also seen the results of some s2000 engine bay fuel fires and they weren't easy to look at.
It's seated fine
![smile.gif](https://www.s2ki.com/forums/images/smilies/smile.gif)
Remove the plastic fuel rail cover. Get a bright flashlight and pressurize the fuel system by turning on the ignition, and check around under and around the intake manifold and fuel hose area. You don't have to start the car at this point. Your nose might lead you to the right location, lol. Look for light moisture around all of the fuel related parts, you probably won't see large drops of fuel, it's going to be a very fine amount of fuel spraying or oozing out from one of the parts. The fuel hose that mounts under the fuel pulsation dampener has a joint in it about 6 inches below the intake manifold, that would be a good spot to check, you need to look down between the intake manifold runners with a bright light shining on the metal portion of that hose.
Good luck.
Good luck.
