Stroking and redline
Old 04-20-2004, 07:30 AM
TurboVtk's Avatar
correct me if i am wrong, and prob am, wasnt the 04 engine increased by boring not stroking?
Old 04-20-2004, 08:42 AM
Hockey's Avatar
No, they stroked it.
Old 04-20-2004, 08:49 AM
Big Ben's Avatar
The '00 to '03 F20C motor has a 84mm stroke & 87mm bore.
The '04 motor has a 90.7mm stroke & 87mm bore.
The K20A has a 86mm stroke & 86mm bore.
My observation of this is that the block responds well to a bore that is equal to the stroke. The K20A is much more responsive to NA mods than the F20C is.
My question is this. Will the crank from the RSX fit in the S2000?
Old 04-20-2004, 09:01 AM
Big Ben's Avatar
If the K20A crank would fit, you could increase the displacement from 1996cc to 2044cc, and increase of 48cc.
The redline could also stay at 9000rpm since the K20A along with aftermarket ECU's redline at 9k. It's been proven to be reliable.
Old 04-20-2004, 09:19 AM
BenR's Avatar
Redline rpm is down to mechanical strength.
I dont know what the TODA kit uses for a crank but the rods are of what seems a forged nature and of a high quality steel alloy coupled with higher PSI rod bolts.
I cant imagine them designing a crank from new, and it does look like a factory steel item. Its probably gone under more intensive lightning and balancing to tighter tolerances than the facotry item.
With vibrations, if the out of balance weights across the plane of teh crank are the same, then the vibration forces will be the same no matter what the stroke and crank speed is. As speed and distance inscrease, the same weights will undergo the same G's and cancel out eachother to give the same vibratory forces.
SO why can the toda kit retain the std redline, simple diferences in the amount of time spent in preparation of the components, and the component quality.
The factory 2.2 could probably take 9k, but why should Honda take that risk when they can keep the engine at the same specific output.
And Ben, an over square engine will always make higher ultimate outputs than a perfectly square motor. The K20 is probably more responsive to traditional tuning methods because its in a lower state of tune as std and packaging restraints are more imposing on induction/exhaust systems.
Our BTCC series CTR's run a max allowable rpm of 8500 and a CR of 12.5:1 yet still make 270-290bhp whilst retaining a plenham setup, abiet a modified (int his case carbonfibre) plenham.
Old 04-20-2004, 10:15 AM
JDMwhore's Avatar
In another recent thread someone stated a TSX crank will fit in a F20C. Anyone have any info on this?
http://forums.s2ki.com/forums/showthread.p...light=tsx+crank
Alaniz also has some new S2000 parts coming to market soon http://www.alaniztechnologies.com/f20c1parts.html
Old 04-20-2004, 10:45 AM
TurboVtk's Avatar
Originally posted by TurboVtk
correct me if i am wrong, and prob am, wasnt the 04 engine increased by bore not stroke?
It makes me so happy to be wrong on this one! major plans now.!
SRB Power
03-05-2008 10:23 AM
infinitys2000
15
10-14-2005 12:44 AM
Mik3
10-06-2005 07:54 PM
KAY'S
09-12-2005 05:36 AM
nelziq
09-25-2004 06:03 PM
Quick Reply: Stroking and redline
