Stroker kit vs. Supercharger ?
I'm guessin that this has been discussed over and over again, but the search and advanced search functions aren't working for me, (so any links would be appriciated)
I know your gonna get more power from the SC but what about reliability and maintenence for a daily driver? I saw a 2.3 Stroker kit for the same price as a SC ( I know labor would be much more ) that claimed 280hp, anyone know if thats at the wheels or flywheel. Also what kinda torque increase could you expect.
Thanks, and sorry if this has been posted before, and before again.
J.T
J.T
the stroker kit will be more reliable as long as lots of r &d were put into it. The only problem with stroking a motor is the fact that you are making the r/s ratio worse, and on a motor that spins to 9k that isnt a real good idea. Just my .02
See the following threads, each of which has some valuable data concerning stroker kits and/or building the head and/or block.
Good luck to you bud.
220 WHP possible NA (for reasonable $$)?
https://www.s2ki.com/forums/showthread.php?...&threadid=88690
Assume F20C engine built to run at 11,000 rpm - What about rev limiter?
https://www.s2ki.com/forums/showthread.php?...&threadid=94510
Stroker kits
https://www.s2ki.com/forums/showthread.php?...&threadid=90779
Stroker kits
2.3L seems like a very tempting project.
just think:::
extrude honed head that has oversized valves with the ports hoggedout
nice valvetrain with titanium retainers
toda or spoon cams
stroked bottom end with 12.5:1 cr
all the boltons and shift around 10.5k
as long as that motor would hold together that would be one helluva beast
just think:::
toda or spoon cams
You'd be dropping the rod ratio down to about 1.5 assuming the pin height is the same - not good for prolonging engine life. Especially at 10,500 rpm.
Also, extrude hone is junk and anyone who blindly hogs out a port should seek alternate employment. IMHO.
