Stripped Spark Plug ; Timesert DIY
Old 12-12-2012, 02:14 PM
  #21
alex s's Avatar
This thread is terrifying and relieving all at the same time.
Old 12-12-2012, 09:57 PM
  #22
Justin Yoo's Avatar
Tell me about it.
Old 01-03-2013, 07:55 AM
  #23
Justin Yoo's Avatar
Originally Posted by chris_barry
One tip is to lower the piston in the bore and fill the cylinder with shaving cream before tapping the thread. Once you have finished turn the engine over and any swarf that has fallen into the cylinder is carried out by an angry looking shaving cream snake.
The shaving cream is essentially soap and moisturizer so wont do any damage. Leave a ball of shaving cream on the bench and its pretty much all gone in a day.
I normally just put 12" of plastic hose on the end of the shaving cream nozzle and fill the cylinder from the bottom.
Totally forgot to mention the piston positioning. Edited in original post. Thanks. Very important step. Might have caused more damage and $$ for another member if you had not reminded me.
Old 01-03-2013, 08:14 AM
  #24
BBV S2K's Avatar
thats usually a common issue.. I've seen LOT'S of S2ks with that same problem in the same spark plug... happened to me too... but I removed the head and went wild reforging those treads...
Old 01-03-2013, 03:10 PM
  #25
Justin Yoo's Avatar
Hahaha looks like you had more time and money. This method seems to work well. I've put on ~2000 hard miles on it so far and not a single issue yet. *KNOCK ON WOOD*
Old 01-05-2013, 04:21 AM
  #26
Billman250's Avatar
Received 1,403 Likes on 840 Posts
If the spark plugs are tightened to 24 ft-lbs, I can assure you 100% this will never happen to anyone else. Go check em!
Justin I'll see you in your other thread.
Old 01-05-2013, 09:16 AM
  #27
s2000maniac's Avatar
Oh damn so now it's 24 ft/lbs?
Old 01-05-2013, 03:03 PM
  #28
Justin Yoo's Avatar
  #29
Justin Yoo's Avatar
Old 09-03-2014, 08:23 AM
  #30
sinistersoups's Avatar
Holy crap this happened to me too a week ago! This thread gave me ease and good info!
Quick Reply: Stripped Spark Plug ; Timesert DIY
