Stripped oil pan drain, following Billman's advice, is this the correct replacement?
Old 09-03-2024, 09:18 AM
Jwong77's Avatar
Default Stripped oil pan drain, following Billman's advice, is this the correct replacement?
Hello All,
I was changing my oil this weekend and when torquing the bolt, I stripped my pan. Yes stupid mistake from a shade tree mechanic.
I would like to follow @Billman250 's advice (link to his advice https://www.s2ki.com/forums/s2000-un.../#post25054165) and replace my plug with an oversized one.
Is this the correct part?
https://www.amazon.com/Dorman-65217-AutoGrade-Oversize-Drain/dp/B000COCX0E/ref=sr_1_3?crid=3KLD280K1MIS6&dib=eyJ2IjoiMSJ9.pAI60ZrOq4Z1BwlXV8J0pZBZxI1PoluWTr_aa9cyKwxBTeCEGKcn7hENK2aBXqFymWpfs1_pLDLIqfrtNIFDdIiQRr6-e1bz6E7U5d1X6xaVFau19eBAO-AbZ4vmvvbaH2soBtBKShEttdKDKE35-sgbSdCMVRVKg8uNjE78fnC-tcAf2Rte-NzPMy50ZbpCoyDHG7VHXe3Eu9rx6BrFJk2iqxI85ltZUAR9T8h29j4.uFrPsiO56kgPUX7Nqg1XaPHIpbloc8NxmfeB4RNrggw&dib_tag=se&keywords=m14+x+1.5+oversize+drain+plug&qid=1725383361&sprefix=M14+x+1.5+over%2Caps%2C174&sr=8-3 https://www.amazon.com/Dorman-65217-AutoGrade-Oversize-Drain/dp/B000COCX0E/ref=sr_1_3?crid=3KLD280K1MIS6&dib=eyJ2IjoiMSJ9.pAI60ZrOq4Z1BwlXV8J0pZBZxI1PoluWTr_aa9cyKwxBTeCEGKcn7hENK2aBXqFymWpfs1_pLDLIqfrtNIFDdIiQRr6-e1bz6E7U5d1X6xaVFau19eBAO-AbZ4vmvvbaH2soBtBKShEttdKDKE35-sgbSdCMVRVKg8uNjE78fnC-tcAf2Rte-NzPMy50ZbpCoyDHG7VHXe3Eu9rx6BrFJk2iqxI85ltZUAR9T8h29j4.uFrPsiO56kgPUX7Nqg1XaPHIpbloc8NxmfeB4RNrggw&dib_tag=se&keywords=m14+x+1.5+oversize+drain+plug&qid=1725383361&sprefix=M14+x+1.5+over%2Caps%2C174&sr=8-3
Thanks in advance!
Slowcrash_101 (09-03-2024)
Old 09-04-2024, 05:43 AM
windhund116's Avatar
Received 1,531 Likes on 1,035 Posts
Originally Posted by Jwong77
Hello All,
Is this the correct part? https://www.amazon.com/Dorman-65217-...s%2C174&sr=8-3
Thanks in advance!
It seems like the correct replacement part.
Jwong77 (09-04-2024)
Old 09-04-2024, 01:20 PM
Billman250's Avatar
Received 1,395 Likes on 836 Posts
S.O. Is single oversize.
That is the correct repair plug.
The following 2 users liked this post by Billman250:
Jwong77 (09-04-2024), windhund116 (09-04-2024)
Old 09-04-2024, 09:01 PM
Jwong77's Avatar
Thanks for the clarification. I found the following piggyback bolt that claims to be oversized as well. Which would you recommend?
https://a.co/d/5PV6ibz
Old 09-05-2024, 05:46 AM
Billman250's Avatar
I am not a fan of piggyback because they do not allow complete draining of the Oil.
Jwong77 (09-05-2024), windhund116 (09-05-2024)
Old 09-05-2024, 08:16 AM
Jwong77's Avatar
Thanks, the new oversized bolt is on its way to me, I'll attempt to replace it this weekend.
Old 09-05-2024, 08:24 AM
noodels's Avatar
Looks quality S/S
Old 09-05-2024, 08:34 AM
You probably already know how to thread it in carefully by hand and clean out the metal shavings. I use a rag to wipe the threads—no pressurized spray to avoid getting shavings into the pan.
Good luck!
Old 09-05-2024, 10:00 AM
Jwong77's Avatar
Good luck!
Thanks! From reading the Helicoil threads, some people recommend I use some axle grease as it would help capture the shavings. I have some Honda Eurea(?) grease laying around, I assume this would be close enough?
I also plan to flush some oil through the engine to flush it out too. The last thing I need is metal shavings getting into the rod bearings or something like that.
Old 09-05-2024, 11:51 AM
Billman250's Avatar
After you install the plug, remove it.
Take one quart of cheap oil, or “clean enough” used oil, and get it up to 150 degrees.
Dump it into the oil fill hole. It will come out the drain hole at speed and take any shavings with it.
The following 3 users liked this post by Billman250:
Jwong77 (09-06-2024), KC2K (09-06-2024), windhund116 (09-05-2024)
Quick Reply: Stripped oil pan drain, following Billman's advice, is this the correct replacement?
