Stripped the Hex Bolts to the Driveshaft
Old 09-17-2005, 12:34 PM
  #21
reds2's Avatar
Originally Posted by Squeezer,Sep 16 2005, 04:17 AM
you could of just used some vice grips
Tried that. Damn things still wouldn't come off. For those who used a dremel, how did you get the blade to the head of the bolt. It's a pretty tight fit.
Old 09-17-2005, 11:59 PM
  #22
spesrf25's Avatar
You have to cut through the bottom of the head of the bolt and the top of the washer. I think that is what you are asking.
Old 06-23-2008, 10:52 AM
  #23
ndk4's Avatar
bringing back the old thread, but i just had taken off my diff to get it fixed. my friend suggested that i use loctite on output shafts when i put them together. what color of loctite should i use? red for the max strength?
Old 06-23-2008, 11:23 AM
  #24
SgtB's Avatar
Use a temporary loctite. It might be purple, but don't hold me to it. Permanent is just that: it's never coming out ever. Temp will keep the bolts in place just fine if torqued correctly.
Old 06-23-2008, 11:52 AM
  #25
ndk4's Avatar
which one would be the temporary one? is it blue? Honda dealer did the last diff install and i believe they had put loctite on output shafts as they were extremely hard to unbolt them.
Old 06-23-2008, 12:03 PM
  #26
Danks2k's Avatar
Don't put loctite on them. They are fine just torqued to factory spec.
Old 06-23-2008, 05:53 PM
  #27
SgtB's Avatar
Loctites FAQ Page
Blue: Can be removed with hand tools
Red: Apply heat to remove
Green: Apply heat to remove
You want blue.
Old 06-23-2008, 07:46 PM
  #28
s2k aok's Avatar
working on those damn internal wrenching 6mm bolts myself and it's the only thing holding me up. i tried using a hammer already but after i cut my socket shorter so i can get a longer ratchet in there i'll give it another go. last resort i guess i'll have to cut the heads off. thanks for the advice fellas...
Old 06-24-2008, 05:30 AM
  #29
ndk4's Avatar
On what situation would the Red one be used? Will the Blue hold up just fine? When I tried to take those nuts and bolts off from the output shafts, some serious ranching was needed to get them loose, I wonder which one was used ...
Old 06-24-2008, 01:50 PM
  #30
SgtB's Avatar
Honestly I don't use loctite too often. I doubt the factory did either. The problem is that the bolts are bonding to the flange due to mild corrosion. You have to hit the wrench sharply. I use a small hammer to wack stubborn bolts loose, or an impact if space permits.
Quick Reply: Stripped the Hex Bolts to the Driveshaft
