Stripped the Hex Bolts to the Driveshaft
Old 05-20-2005, 01:57 PM
4doorj's Avatar
oh ... when i was replacing my clutch.... those hex bolts were the hardest thing to do!
soooo stressful!
Old 05-20-2005, 02:02 PM
Billman250's Avatar
Received 1,401 Likes on 839 Posts
I've found if you use a high quality 6mm hex socket, and square it up on the bench grinder so it grabs all the way down, you'll never strip them again. The socket I use now, I square up with each job. Been about 4 cars so far, none stripped yet.
Old 09-15-2005, 05:49 AM
Habitforming's Avatar
Thumbs up
so if these bolts are not stripped upon removal, do they still need to be replaced (per factory service manual it says to replace all)?
I'm doing a clutch job this weekend, and I'm hoping I can put it all back together after I'm done. Too late to have order these bolts for saturday. Sure wish I had seen that in the manual earlier, never guessed those would be a replacement part.
Old 09-15-2005, 06:30 AM
Stratocaster's Avatar
Many of us have reused them.
https://www.s2ki.com/forums/index.php?showtopic=320622
Old 09-15-2005, 08:09 AM
Billman250's Avatar
If they come out easy, and the hex is is nice shape to properly re-use them , go for it
Old 09-15-2005, 01:07 PM
duely noted. I will try to be careful with them on removal
billman, I'm starting to think you are stalking my posts. I think you have answered each one of my questions since I arrived here a few weeks ago.
Old 09-15-2005, 01:17 PM
Billman250's Avatar
I guess it's just habitforming
Old 09-15-2005, 08:57 PM
reds2's Avatar
Been there done that. I took it to the diff shop and had them pull it. They welded a bolt on and got it out that way.
Old 09-16-2005, 04:17 AM
Squeezer's Avatar
you could of just used some vice grips
Old 09-16-2005, 05:28 PM
E White's Avatar
billman ... what are you doing exactly when you say that you "square" them up? Not sure I understand what you are referring to.
Quick Reply: Stripped the Hex Bolts to the Driveshaft
