stripped bolt?
Nothing that is going to be cheap or easy.
If the bolt is really stripped there shouldn't be much holding it in place. To repair the problem you'll need either a new thermostat housing, or attempt to install a helicoil in the old housing. You'll have to remove it to drill for the helicoil, and you need to make sure that it's installed parallel with the other bolt and at a 90deg angle with the housing face. Not the easiest thing to do freehand.
The threads are there for a reason man. I suppose you could waste a bunch of time trying to glue up the outside and have it still leak. The thermostat needs 2 bolts to hold it in place and hold 16psi + of cooling system pressure inside.
The next question is how did it get stripped?
Find a replacement bolt 1st. No point in taking it out when you don't have a new one go go back in.
There are several tools available for removing rounded fasteners. A pair of vice grip locking pliers is the easiest to find, and you may be able to get a small pair into place to loosen the bolt. There are also specialty sockets made to cut into the sides of the rounded bolt. If you don't think you can get the bolt out, find a mechanic that can.
