strange grinding sound for a split second after not being started for a week help
hi everyone ive had my 04 ap2 for about 7 months now with 76k on it never had a problem, well yesterday when i started it for the first time in a week, it made an abnormal grinding sound for about a split second right at startup(outside temp around 70degrees so not too cold)(sound sounded exauctly like a gear grind)like as if the starter wasnt pulling off the flywheel fast enough and grinded,but started up nicely, not a slow start, not a bad idle nothing wrong at all... let it warm up shut it off and started again sound was gone...? my question is this my starter going out? should i change it? i let the car get cold again for about 8 hrs and started it up again still no noise again. should i worry or was it just because it hadnt started for a week or so? any advice would help very much thankyou
thankyou for you quick responce makes me feel a bit better, just want to know if it does become a common issue what do i do from there? replace the starter? replace the flywheel? or both?
mine does this randomly too. i figure once it does it consistently i will replace the starter. its kinda buried in there behind the alternator i dont feel like cursing and yelling at the car for the foreseeable future.
s2000maniac
10-10-2012 08:13 AM
