A Strange Dealership Service Receipt
I just came home from having the S2000 serviced at the local Honda dealership. The clutch master cylinder was leaking, so they replaced it under warranty.
Looking at the receipt now, I just realized what it says:
211101 CLUTCH MASTER CYLINDER - REPLACE. FOR 2007> CR-V, NON-US ONLY. S/B# 02-002 S/B# 98-084
211010 CLUTCH FLUID - BLEED. FOR 2007> CR-V, NON-US ONLY.
wat.
I've heard horror stories of dealerships mixing up the CR-V's diff fluid for the S2000's. I don't think they'd be stupid enough to put a CR-V master clutch cylinder in an S2000.
Any ideas?
wat.
Any ideas?
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
Could it be the same part for both the non-US CRV and the S2000?
I didn't think they made a standard shift CRV for the US market. (maybe the earlier model was available with a stick shift here in the states)?
^Different part numbers. The S2000 part number 46920-S2A-003 is unique and has been unchanged for all models, all years, and all markets.
The overseas CR-V variants have had these part numbers:
1998-2001: 46920-S10-003, 46920-S10-C01
2002-2004: 46920-S7A-A01, 46920-S9A-J03
2004-2006: 46920-S7A-013, 46920-S7A-A02, 46920-S9A-J04
2007-2009: 46920-SMG-033, 46920-SWY-020
The overseas HR-V had part number 46920-S2H-003 (1999-2005), which is only one character different (tech might have made a typo).
go to majestichonda.com and do a search on the parts on both vehicles and see if they are similar part numbers, easy way to ease your mind before you can speak with Honda.
