strange "in-cabin" buzz during clutch buzz
King snorkel, i know the EXACT noise you are talking about. sounds like clutch buzz, but quieter/sharper. comes from under the dash on the drivers side.
I wish i knew, I have it too but never looked into it.
Originally Posted by Greece_S2000,Jun 11 2008, 02:23 AM
On the left side small fuse box in the engine bay there is a thick wht/rd I think wire underneath that runs exetremely close to the inner fender . When this wire resonates ( about 3000 rpm ) it makes the sound you describe . If this is your problem you'll also find sings of rubbing on the paint of the inner fender . The clutch pedal rod does resonate too but it's more like rattling and it can be stoped with grease for clutch forks .
Anybody have any luck finding out what this is?
It just started to happen to me today on an 06.
I kinda hoping it doesn't come back, but if it does my first plan is to inspect the clutch petal/master cylinder linkage.
I blew my clutch master/slave cylinder last week and had both of them replaced. It was bad - my clutch pedal felt like I was stepping on a smushed Twinkie. Not to mention that I had fluid coating my clutch pedal arm...
Anyways, I explained the noise and had my mechanic re-grease any connection points under the dash. Sadly, the noise came back.
I'll look deeper into the clutch fork/throwout bearing connection when I finally change out my clutch but I have a feeling that it will go away when I upgrade to the new OEM disc.
