stranded on road need help!
#21
Thanks again for all of the advice. I will try and check the pump in the morning. How much fuel should come out after cranking it over??
So far still no luck with getting the car running. I tried the MAP sensor wack already but no luck. What is the possibility of being a clogged fuel filter??
#23
Map sensor could do in your car also. Double check all your connections.
BTW how many miles on your car? And did you upgrade your fuel pump w/ the SC?
Try to hook up a laptop to the EMS and get your AFR reading.
#25
BTW...how much fuel is in the tank?
#27
Thanks again for all the help. Lucky for me Viets2k was in the area and able to cme by and help me out. He was able to determine that it was the fuel pump and got me to a shop that had a pump and would be able to change it out. The guy is a lifesaver!!!!!!!
The car is at the shop now and will hopefully be fixed today. I will post again and let everyone know how it turns out.
Car just broke down. Vortech sc. Aem ems. Weak power and sounds like an sti so misfire I'm guessing.
Moddiction
02-21-2012 08:22 PM
