stock shift knob orientation
Hello, I recently bought a 2004 silverstone s2000. I love the car, and I just recently upgraded the stereo with the Modfiry DCI which made the steering wheel control work like a charm
Anyways, back on topic. my stock shift knob orientation is not correct. The lettering is facing north west when it should be facing south.
The nut at the bottom of the shift knob is tighten to the point that I can't turn anymore without fearing that I will messed up the threads.
When I remove the nut and put the knob back on, it is facing the right way (south).
Do I need to keep the nut there or should I not be afraid of tightening it more?
The nut is supposed to be tightened against the shift knob, not the base of the shifter. Take a look at this link, I used it for my Fit and the concept should be identical: http://www.bernardiparts.com/Images/...b_AII42201.pdf
Hope that helps you out.
-Evan
-Evan
