"Stock" Dyno - Interesting findings
I don't have a scanner, but I had my 2002 S2K with 15,000 km's dynoed on a DynoPack last week...My only mod was a AEM CAI...
My best run was 204.7 RWHP
Torque 132.1 lbs
Is this pretty much what stock S2K's put down?
Torque 132.1 lbs
UL,
Any particular scan tool you would recommend? I have a laptop, so a realtime logger with PC software would be ideal..
Looks like Autotap http://www.autotap.com/autotap_windows_products.html has a generic import scanner for $200 with windows software - Are there any that provide add'l "honda specific" diagnostics?
Thanks
Thanks
Torque 132.1 lbs
Torque 132.1 lbs
Could be that Dynapacks vary from dyno to dyno too! I've seen variations of up to 5 hp on different dynojets (although some are very close to each other), so variation on a Dynapack shouldn't be surprising.
One more reason you should pick a dyno and keep going back. :-)
jahwerx, any decent tool is fine, as long as it has fine resolution datalogging. Data every 1-2 seconds is too slow (should be every tenth of a second or so, so a minimum sample rate of 10 Hz, and hopefully much higher so you can sample multiple variables).
UL
UL
