Stock AirBox
Stock AirBox
A question for all,
if you open up the stock air box, you will see a wall that divide the box into 2. From what I heard, the wall is suppose to cancel the sound. I was wondering if you cut off the wall which will increase the mass of air flow coming in form the opening, would it increase HP? If this work, I (we all) can save some $$$ and not risk any hydrolock from aftermarket CAI.
Give it some thought and let me know.
Cheers.
Cheers.
It's been talked about before, and it may slightly help power. There's no proof though, and if you remove everything inside the air box you will lose the water catching ability that prevents ingestion of water into the engine when you run a snorkel type CAI.
Cheers.
I took mines out and i couldnt tell the diff ...
i did notice the diff with the cover on and off . with the cover on and with out the divider in place , my car toped out at 116mph going up this hill . when the cover is off , i hit 119mph and climbing .
with it off , it helps on the high end with more air being easyer to suck in , but in stop and go traffic . the car sucks ass ... i notice it drives smoother with the stock air box on and less bogging.
The first chamber under the AIr intake duct is a silencer. I don't think removing the wall will increase airflow because all the air still has to go through the intake duct. The duct goes directly to the chamber with the air filter element. Removing the cover completely will increase airflow, but it's all hot air heated by the engine. It sounds better, but most report loss of power. I'm surprised usdm got better performance. Was it much cooler when you did the 119? Cooler air temp may have overcome the air being heated by the engine. Was it 45 degrees in HI that day ?
s2w:
it seems in stop and go traffic the car runs worst than with it on ... i guess when i went up hill at a high mph , air was easyer to get in which helped out on the high end . i currently drive with the car bone stock , because it feels smoother , i tend to get a bogging every now and then .
as for the air temps , i did 119mph after work around 5:30pm with air temp around 80degs and 116mph around noon time , ide say temps around 82-90 degs i dont think that would make a diff as too the performance it did .
