Still have ABS light after sensor replacement
I stretched out my front sensors while installing springs and got an ABS light. the Codes were 11, 13, and 50 something (the ABS Modulator) So, I got a set of front sensors from a member here. (i was assured these were not damaged) I installed the new sensors and attempted to reset the light, but could not get it to clear. I figured the light should eventually clear itself, but i've driven it about 30 miles since the install and the light is still on. I just need to figure out if the sensors are still the problem or if the codes are just the old stored codes. Am I doing something wrong in the reset process? I followed the Honda service manual by the jumper and brake method. Any help is appreciated.
kaansahbaz
10-02-2014 04:22 PM
if lookz kill
11-29-2006 04:06 PM
