"Sticky" steering?
Old 05-10-2009, 11:26 PM
badboy00z's Avatar
Default "Sticky" steering?
Whenever I turn the steering wheel at low speeds, it feels like it's sticking. I would also feel vibration and somewhat hear a "thud thud thud" sound as I turn. What could the problem be?
Old 05-11-2009, 02:12 AM
lotus7racer's Avatar
Will this help?
https://www.s2ki.com/forums/index.php?showt...=0&#entry683385
Old 05-11-2009, 06:01 PM
badboy00z's Avatar
Not really. I think it only happens when it's cold though.
Old 05-23-2009, 03:10 PM
badboy00z's Avatar
Bump. I still have this problem. It only happens when the car is cold. Any ideas?
Old 05-27-2009, 08:54 PM
Kirpich's Avatar
Check tire pressure?
Old 05-28-2009, 01:02 AM
badboy00z's Avatar
I'll try that. It might be it since it only happens when it's cold. How fast does the air in the tire heat up?
Old 05-28-2009, 05:59 AM
SgtB's Avatar
It's not the tires. The s has a mildly defective steering rack. The cold makes it act up until warm.
Old 05-28-2009, 02:16 PM
badboy00z's Avatar
I see. SgtB, do you have this problem too? Would a rack from a newer S fit and fix the problem? And is it worth it?
Old 05-28-2009, 02:59 PM
Kirpich's Avatar
A $700 job for a different 'non-sticky' rack? Nah.
Old 05-28-2009, 05:25 PM
zzziippyyy's Avatar
bad rack or try unplugging and replugging the harness under the wheel. Could be a bad connection
Quick Reply: "Sticky" steering?
