Sticky Clutch Pedal
Old 10-19-2009, 01:29 PM
cougar hunter's Avatar
Default Sticky Clutch Pedal
I recently noticed that after I press in the clutch pedal, it feels like its getting stuck for a brief second and then feels a little scratchy on it way up. I tried the Sticking Clutch Pedal DIY and it didn't work. Is there anything else I can try to fix this?
The only thing that I did not do to follow the DIY 100% is grind down the nipple and the push rod. I cleaned it and re-grease everything, but it still has the feeling.
Old 10-19-2009, 03:06 PM
arkkornkid's Avatar
Could also be a bit of binding where the pedal connects to the shaft of the CMC. I put some grease on the end of my finger and gave all that a good coat and it cured my problems.
Old 10-19-2009, 09:51 PM
chansta's Avatar
maybe throw out bearing worn out and is grinding on shaft? maybe fork is bent. jus some ideas.
Old 10-20-2009, 07:49 AM
I'm gonna go pick up some sand paper today, and re-do the DIY and see if that helps. I'm also going to put some grease on the clutch pedal spring.
Old 10-20-2009, 05:15 PM
Bricksnite's Avatar
Where the clutch spoon thing pivots and goes into the tranny, it splits into 2 fingers that grab on the throwout bearing. Mine had the same symptoms and i looked inside the little clutch slave cylinder port in the tranny and you could see the 2 fingers that grab the throwout bearing were 100% dry and rusty. I reached in with a little brush and greased them and it was a huge improvement.
Old 10-20-2009, 06:37 PM
did you take the big boot off that is connected to the tranny itself?
Old 10-20-2009, 11:43 PM
Fast Jack's Avatar
got to take the boot off to see inside.
Old 10-21-2009, 07:15 AM
I also want to add, that I have noticed that the pedal gets easier to push and the stickiness goes away with more spirited driving
Old 10-22-2009, 11:27 AM
did this today and it fixed the problem. thanks a bunch.
Old 10-22-2009, 03:40 PM
ronnuke's Avatar
I am glad you got it remedied.
I tried that on mine and it fixed mine too....for about a week.
I ended up having to replace my throwout bearing and throwout bearing guide shaft and THIS time I made sure and used the proper grease...the Super High Temp Urea grease from Honda. Accept no substitute. If you find you must also go down this path make sure to fill the valley in the throwout bearing with the Urea grease and adequately grease clutch fork pivot points and ends (that you greased in your fix) and the slave rod and cup in clutch fork.
Quick Reply: Sticky Clutch Pedal
