sticky clutch pedal
hello, guys, every time i push my clutch pedal in; it feels sticky, like it won't come out as fast as it used to do it. what could this be?
i changed the clutch like 2 months ago for a stage 2 clutch and a fidanza flywheel.
Check out this link:
https://www.s2ki.com/forums/index.php?showt...dpost&p=7253853
It fixed it for me, but I have a stock clutch setup. Good Luck.
EDIT: Grease the release fork also.
A few things to check.
1) Air in the clutch line. I would first bleed the line before doing anything else. This is very likely the case because your had your clutch changed not long ago.
2) Clutch fork is bone dry. If your mechanic didn't know what he was doing, he probably didn't grease the fork.
3) Bad slave or master clutch cylinder. I would look for leaks before changing to new ones.
BerlinaBlack_AP1
10-03-2010 06:55 PM
