Sticky Clutch
Old 03-01-2006, 07:36 AM
Lundunb's Avatar
Default Sticky Clutch
My clutch just two days ago started sticking for just a quick second when I let up off of it. My car doesn't feel any different and I don't slip out of gear or anything. It just started sticking. It does it only when I push the clutch all the way to the floor. Has this happened to anyone? If so, what the hell is going on? Please, someone tell me something!
Old 03-01-2006, 07:40 AM
SIIK2NR's Avatar
https://www.s2ki.com/forums/index.php?showt...k+\+clutch
Old 03-01-2006, 09:09 AM
slalom44's Avatar
https://www.s2ki.com/forums/index.php?showtopic=170223
Old 03-01-2006, 12:54 PM
dbzerk's Avatar
I'm having the same problem too..
Ive lubricated/ WD40 the fork which was a 2 day fix.. but the problem is back again..
Old 03-01-2006, 07:25 PM
Yflyer's Avatar
On a six year old car, could be slave or master cylinder. My bet is the salve cylinder.
Old 03-01-2006, 09:02 PM
Billman250's Avatar
Received 1,401 Likes on 839 Posts
It needs to be greased at two points:
Where the ball end of the slave sits in the fork.
Where the tips of the fork contact the TO bearing. You'll need a small paint brush and a very good eye to get this right.
It will be mint...trust me
Old 03-02-2006, 01:10 PM
dbzerk's Avatar
Got a pic of the points where i should grease??
Old 03-02-2006, 01:57 PM
Billman250's Avatar
No.
Old 03-02-2006, 02:27 PM
kent-k's Avatar
what is the best grease to use in this application?
Old 03-02-2006, 03:16 PM
Billman250's Avatar
Any wheel bearing grease that is thick like peanut butter will work well
Quick Reply: Sticky Clutch
