sticky clutch ?
sticky clutch ?
Hi guys,
my clutch started doing something that perplexes me. Its sticky when its all the way to the floor. Engaging the clutch is fine, but when I go to let it off the floor its like someone stuck a piece of gum to it and it sticks on its way back up. I also noticed the pedal is a bit stiffer than usual, but the issue seems to come and go.
I checked the fluid, full and no leaks. System was gravity bled last year with ATE blue.
Clutch master and slave are only about 2 years old.
Clutch is only 2 years old, all OEM except for PP. Billman replaced the clutch so I know the job was done right.
I never ever dump the clutch or beat on the car.
Feels like this stickiness is in the pedal. Car shifts normally. Checked to see if its slips and it doesn't, performs normally... Any ideas??
