Steering Wheel Not Aligned
Just I have the alignment checked. Any signs of a crash or wreck will become obvious with the results. But from the sound of it I wouldn't be too worried, all cars will be off somewhat if an alignment hasn't been done within the last year or so.
Its most likely an alignment issue. If you need to replace tie rods your looking around $175 in parts for inner and outer tie rods. If the owner knows about the issue they should also know when it originated and what caused it. Maybe make the purchase contingent on an $80 alignment?
The thing is, the misalignment of the wheel is so slight that I probably wouldn't have noticed it if he didn't mention anything. So I'm really hoping that it's only an alignment issue. Although I don't know why he wouldn't have gotten it fixed over the year that he owned it if it was something that simple.
Did it pull or wander when driving it straight?
If you looked at the tires, were they worn evenly? Sometimes if the car was aligned on old tires, a new set of tires will cause the steering wheel to be off with the old alignment. Big differences in toe &/or camber from side to side can cause both steering wheel off center and irregular wear. Also if the alignment shop aligns the front before the rear that can cause it too.
To test for alignment or steering issues, take it around low speed turns and pay attention to: 1) any noises (clunking, clicking, rubbing, rattle, etc)
2) steering effort going left and going right - it should be even/smooth in both directions and linear (no skips, hang ups or low effort spots)
3) how easily the steering wheel returns to center after the turn - should be even in both directions and return completely (or very close to completely) to center
I think this may be the issue with my car after the steering rack replacement, so I'd like to try this. Could you briefly describe the process?
Originally Posted by cdelena' timestamp='1393258126' post='23031331
The one I saw was NOT an alignment issue. The shaft was simply reconnected a spline or two off when reconnected after a clutch job. It is a ten minute fix with a 10mm wrench.
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-3yr.png)
If they've ever put on aftermarket suspension parts/lowered that could affect it too. I bought mine and during the inspection, the mechanics (at a shop that does tires/alignments) noted the off-center steering and said I needed an alignment. Previously it had coilovers one but were removed, and I don't think it was realigned
