Steering wheel calibration
Hello guys,
I did alignment lately, my toes are identical and correct for the front tires, and everything seems to be correct on the alignment machine, though my steering wheel is tilted to the right a little bit.
Is it related to some electric calibration? Is it because it's EPS?
How to calibrate the steering wheel without affecting the alignment that I did.
yes, chances are they didnt put a steering wheel lock on it when they aligned it...we use a spring loaded tool that wedges between the seat and holds the steering wheel in place...just take it back to whoever did it and tell them the steering wheel isnt straight
Steering wheel orientation is a mechanical attribute. There is a direct connection between the steering wheel and the front tires. The EPS is only a boosting device to give it power steering. Doing an EPS calibration won't do a thing to the placement of the s. wheel vs the position of the front wheels. You may as well wave your magic wand at it. 2 posters have already told you what happened. I'll be the third. The guy who did the alignment overlooked the position of the steering wheel or he was just lazy and didn't bother with it. Each side's steering rod needs to be adjusted the same number of turns after the steering wheel is set to the proper position. If the s. wheel is tilted to the right, it needs to be pulled back to the left till it's straight and under no stress. Then the rods need to be adjusted to move the front wheels to the right.
If the steering wheel is off by less than an inch, I wouldn't mess with it if the alignment is good now. If the alignment guy was so lax that he didn't leave you with a straight steering wheel, he'll probably screw up the alignment trying to fix this.
