Steering Issue
Sponsor
Steering Issue
Just wanted to get some feedback from the board...
The steering wheel seems to have a few degrees of play. It is almost like you can turn the wheel back and forth, while at speed, with out affecting the direction of the car. It is like you can "tap" the steering wheel back and forth.
It is extremely annoying wheel turning through a curve with a varying radius as you can not keep the steering wheel tight against the steering mechanism.
The weird thing is, it is not consistent, some days it is not there and there is no issue, except the steering does not feel as hard as it used to.
Thoughts???
Thanks for the feedback..
Thoughts???
Sponsor
i had the same problem. i was doing an alignment after i got the clutch installed and noticed a little play in the sterring wheel. sure enough the steering coupler bolt was finger tight
