Is this the steering angle sensor?
So I installed my NRG short hub, put everything together, took her for a spin and noticed that my wheel was off by like a tooth. So i pulled everything apart, and when i removed the hub, the green plastic piece went with it.
I didn't reef on it or man handle anything in anyway. I thought it was weird, and figured I broke something, but put it back together anyway. I then noticed that my VSA and (!) lights were stuck on. Turning the wheel 360 in either direction didn't reset the lights either.
I'm wondering if what i broke was, in fact, the steering angle sensor? I'm aware that i don't have VSA now, which isn't much of a concern to me. but i'd still like to fix it at some point.
Thanks guys.
Thanks guys.
Anyone? I'm being told that it's the body switch. Is this the same thing?
I know that I should pick up a manual at some point, but after doing extensive image searches, the only thing I can find that looks similar is what i found below.
http://www.hondapartsunlimited.com/h...me=body-switch
EDIT: disregard. Looks like they're one and the same. However, the part I listed is for pre 2006 models. That's why they're so cheap. 06+ are something like $200.
That green piece wasn't there when i took the hub out of it's box prior to install. oh well. i don't really care if i don't have vsa anyway.
maranelloboy05
10-25-2014 11:36 AM
