starting up in serious cold
#41
Originally Posted by SPEEDFUZION,Jan 20 2005, 11:52 AM
ITS NORMAL FOR IT TO BE HARD TO START WHEN IT PERRY COLD BECAUSE OF THE HIGH COMPRESSION RATIO IT RUNS
PS. PLEASE TAKE OFF YOUR CAPS LOCKS WHEN YOU POST. IT'S CONSIDERED SHOUTING AND IT'S RUDE!
#42
Well, the high compression ratio does have an effect since the battery/starter has to work harder to push against the more tightly packed air. How much of a difference at cranking speeds that would be I don't know. Maybe leak-down would virtually eliminate it given the slow speed of the crank?
