Starting up and immediately shutting down.
It looks like the car sat for a very long time, to get that rust onto the cams. I'm going with bad gas, as the main cause of your problems. I really never heard of OEM S2000 fuel pumps giving out, under normal circumstances.
You prolly should drain the remaining gas out of the tank and clean out the lines & filters.
Good luck!
Good luck!
Rust on cams is common with cars that have catch can fitted, but not drained for winter storage. In short time (single winter storage), cams get nasty rust.
windhund116 (03-18-2023)
Hi all,
Posting an update here. We managed to resolve the issue. Although the lack of coil lead gasket/seals was problematic, it was not causing the issue. The underlying problem was that the clip holding the hose-pipe between the fuel pump and the fuel filter snapped and gas was not flowing with ample pressure. Replacing this clip resolved the problem. Needless to say, the car had a full service while at the mechanic, replaced every single drop of oil, filters, etcetera, because the previous owner was clearly very negligent.
While resolving the fuel pump issue, we discovered that the fuel tank is rusted... probably rusted beyond saving.... so I am going to try to purchase a new fuel tank but can't seem to find any under part number 17500-S2A-932.
windhund116 (03-23-2023)
Glad you fixed in, and that you came back to tell us what it was.
Should be easy enough to find a used tank in good condition.
s2000 issuses
I have a Honda s2000 ap1 I changed the fuel injectors and now my car will start and automatically die , not sure what's going I tested the ohms on the fuel injectors and everything seems fine. any suggestions on what could be causing to make it start and die automatically
Received 1,377 Likes
windhund116 (02-06-2024)
Metcalfe
06-27-2013 12:34 PM
