Starting Problems
Starting Problems
OK looking for some suggestions on what problem may be. Got in the car this morning and it took about 3 seconds to turn over, I thought nothing of it the first time, but its been happening every time I have started the car since. Here is what has happened with my car in the last few days, uninstalled my vafc w/harness and put it back on (same settings done on dyno) , put gas in it two days ago, im wondering if I have a battery or alternator problem. Once the car is started it runs fine. Ideas? Thanks in advance
Jeremiah
Jeremiah
Ok part two, the battery and alternator are fine , just had them checked at auto zone, so I bought some gas treatment (water remover) and fuel cleaner (5 bucks total) figured it was worth a shot. If anyone has ideas let me know thanks
Is the VAFC installed with a PnP harness? Or did you unplug the PCM? If so you need to re-do the Idle learn procedure. Start the car and let it run at idle with no additional loads. Untill the cooling fans cyle.
Ok while going to lunch it did its intermittent thing, Stuff I have checked so far, battery (good) , alternator (good), I have even added fuel water remover and cleaner and dont think that has done crap either, anyone think it could be a sparkplug or injector problem. I am going to take the VAFC completely out and plug the ecu in and see what happens also. Thanks for all suggestions (BTW No CEL)
After pulling the VAFC and starting it , it did the same thing. So I start looking under the hood and found the problem this thing (in picture below) was loose, so I tightened it and it started right up
Thanks for the help everyone (will leave thread open until someone identifies that connection)
