Starting Problems
Starting Problems
Ever since ive had the car its had a starting problem. It takes about 5 seconds longer than it is supposed to to crank before the car will actually start. After the car has been sitting for a few hours or more the car will start up just fine but after sitting for just a few minutes to an hour or even after putting gas in the tank the car wont start at all it will just crank. So I would have to manually push start it.
I've been told recently that it has something to do with the fuel. My plugs are new and my fuel injectors are aftermarket. My uncle is a mechanic and he probed each of the injectors and said that they were all fine except for #1 which was a little loud until he moved it around. I had a friend who mentioned it might be my coils.
I am getting horrible fuel economy and my car idles funny sometimes.
I have these MIL codes I got from Autozone if these would help to find the source of the problem:
P0300: Random Cylinder Misfire
P0301: Cylinder 1 misfire
P0304: Cylinder 4 misfire
P0135: Sensor 1 Heater System Malfunction
I most likely need just an o2 sensor for the last code since it had oil all on it from when my turbo started leaking.
Thanks to all that can help!!
it actually sounds like a fuel problem... the reason I say that is bc one it starts and runs you are able to start it with ease? correct.... the fuel seems to be draining back into the tank... do your injectors prime fully.... test it by turning the key on but not starting it a few times and see what it does.. let us know
Question:
Did these codes occur after you changed the spark plugs and injectors?
Many times we need to go back to stock, original OEM, or even First Base to find the issues. What is the Brand and Model# of the plugs you are now using, Size of the injectors (if after market, some need two o-rings).
Clear the codes, start and run engine, then reread the codes (if any).
RePost your findings.
Question:
Question:
Question:
