Starter grind
Old 06-03-2005, 07:11 PM
Chazmo's Avatar
^ Thanks!
Old 06-03-2005, 09:00 PM
S2000Patrick's Avatar
Thanks for all of the ideas as to what it might be. As I said it is very intermittent, all is quiet right now (no extra sound). So I will have wait and jump into diagnostic mode when it starts acting up again.
Old 06-03-2005, 10:16 PM
xviper's Avatar
Billman, I have not heard what this tensioner sounds like when it starts to go bad. However, I do know what a stuck Bendix sounds like and it is very distinctive. Are you saying these two sounds are similar?
Old 06-04-2005, 03:52 AM
Billman250's Avatar
Received 1,397 Likes on 837 Posts
Hmmm....you won't hear any high speed whine, like a starter motor overspeeding.
It's a very distinct noise, like a ratcheting
If you've ever put any new automatic Chrysler product in gear, it makes a rapid clicking sound. That's about what it sounds like. I have an audio clip, I will try and post it later.
Old 06-04-2005, 05:01 AM
gerardog's Avatar
I had this noise for a while, had the timing belt tensioner replaced and it still does it every once in a while. I've noticed that it's more common on cold starts and if the car has been sitting for a while. I don't know what to do about it... but i hate that noise!!
Any suggestions?
Old 06-05-2005, 01:12 AM
arcadence's Avatar
I'm guessing this is my problem, and I'll look into getting the timing chain tensioner replaced. Thanks.
Old 06-06-2005, 05:37 AM
Squeezer's Avatar
so the s2k's timing chain tensioner gets tension through oil pressure and not from a spring?
Old 06-06-2005, 01:36 PM
Billman250's Avatar
Both...
Old 06-06-2005, 02:10 PM
Nate03's Avatar
almost sounds like a locust or chicada that you hear seasonly in the trees...for a few seconds
I haven't heard it in my S - but I did think that sound coming from the wifes Jeep (Chrysler) when put into gear was sort of strange...
Old 10-05-2014, 01:14 PM
richscotti's Avatar
These are different noises. I replaced a TCT on an earlier model. this noise is more grinning in nature than the TCT sound which like a card in spokes. This grind is a poorly greased bendix which causes no problem. The TCT noise is when the car is warm. The dry bendix noise is when the car is cold. Billman is 99% right, this is the 1%.
Quick Reply: Starter grind
