started up my S for the first time since
Old 04-11-2009, 08:53 PM
Suzuka_Joe's Avatar
Gas separates over time so gas stabilizer will keep u from having to drain the tank and ensure there is good gas in the car.
Old 04-11-2009, 09:55 PM
SquirtleS2K's Avatar
You gas should be fine enough to ride on if it is less than a year. I would not go into Vtec or even higher than 3.5-4k The burn off was probably the wd-40 like mentioned above. Glad you are back from deployment!
Old 04-11-2009, 10:23 PM
Kdlopez01's Avatar
When I got back from my deployment I had to buy a new battery, but the one thing I was most worried about was valves being under compression for such a long period of time. . .
Old 04-11-2009, 10:24 PM
Kdlopez01's Avatar
Yeah should off added stablizer too to keep the fuel fresh I kept mine under half a tank before adding stabilzer and storing it FTW
Old 04-12-2009, 04:52 AM
SC_Highlander's Avatar
I bought a wrecked S 2 years ago to convert into a track car. It sat for 15 months while I repaired and stripped it, then fired up on the first try when I was ready to haul it to it's first event. The gas won't be a problem
9ineballer
01-07-2014 03:27 AM
goldenfri
02-25-2010 08:28 PM
dennisp
07-10-2008 12:45 AM
Lurking Lawyer
03-23-2005 04:07 PM
Frisky
09-13-2002 02:07 AM
Quick Reply: started up my S for the first time since
